Reverse Lights Wire?
GAShan
I'm putting a nav unit in the Ty and would like to know the easiest place to pick up the lead for the back up lights so the unit knows when I'm going backwards. Is it available under the dash or does it go back from the shifter in the center body harness? If so can I grab it in back somewhere without taking the truck apart (again)?
GAShan
Never mind, found it. Light green wire in 10 pin vertical connector on right side of fuse box.
