Re: Removing lower front seatbelt
Ok I finally got the two bottom front seatbelt assemblies removed. How I did this was.
First take the plastic rectangular cap off of the bottom from lower seatbelt by the rear speaker panel.
Using a T-50 torx socket and a long extention ( mine was about two feet long) position the torx socket on the bolt, make sure to have the extension complete straight and pushing up against the plastic trim around the seatbelt to make sure the socket is fully seated before you go try to turn the bolt.
I had to use a large breaker bar on mine because the bolt would not budge, I used a three foot breaker bar and got the bolt out no problem., it was a good deal of work and the bolt was really in there tight.
At first I tried using different swiveling socket extentions but the straight one worked out the best in the end. Also, something to note, these seatbelts need to be removed to gain access to the screws that are holding in the rear side panels, without removing the seatbelt there is no way to get to the remaining screws, without breaking the panels.
Good luck and let me know if I can answer any questions.
Thanks for the help guys,
Nick
