My Permacool remote trans filter lists the Fram (for reference) PH8A or PH43 as correct filters. Problem is both of them are plenty bigger than the adapter, and space is non-existent. Though one's shorter, it's not the length that's the problem. I found a PH46 that'll fit and is the same diameter as the adapter so it'll fit w/ minimum hassle. Aside from physical size is it safe to assume that a filter with the same size and thread inlet is capable of acceptable flow? I know the smaller filter will not last as long as a bigger one, but I change the fluid when I change my engine oil,so no problems. Thanks,
Jeremy
Jeremy
