tbauer03
TRBOBOX
I swapped out distributors today because It wasn't getting spark and i suspected it to be the pick up coil. Anyway when i pulled it i marked where the rotorbug was pointed thinking when i dropped it back in it would lock back into that position because that would be the only way the oil pump would allow it to go in (or 180* opposite) But when I reinstalled it would only fully seat about 20* clockwise from my mark. I figured if i kept the distributor hold down clamp loose enough i could rotate the base enough to compensate. Anyway it wouldn't start or attempt to fire. It appeared to be sparking based upon my timing light flashing. So my question is did i make an amauter mistake by severely adjusting the timing to the point it won't fire or is there something else to look at (fuel)? Thanks for any input.
