rear shocks???
Shopping4Ty
The rear drivers side of my Ty sits higher than the pass. Even when the rear leveler pumps up the drivers side still sits higher and the wheel sticks out farther the the pass. side. What should I consider first, shock? hose?
And why would the drivers side wheel stick out farther?
Thanks for your help guys!
ParTyBoy
Re: rear shocks???
More than likely your torsion bars just need some adjusting...
Shopping4Ty
rear leveler
rear leveler
Is there an adjustment on the compresser to set how high the rear end of my Ty sits??? If so where is it?
Thanks!
Phoon30
It's a common thing on the 1st gen. S-Series to sit lower on the driver side then the passenger side. Probably because most of the time there's more weight on it- you, the driver.
GM TURBO
Sell Out
The adjustment for the rear shocks is quite easy.
First - Pull the fuse labeled ELC.
Second - Buy 2" drop springs.
Third - Buy new shocks.
Fouth - Install the parts you just bought.
Done - you will soon find your Ty sitting at a respectable level :)
