rear lights
dogboy
uk typhoon
hi guts dopy question time i have a europeon moded typhoon ie ligthing regs are diffrent.so do state side ty's have..1,rear fog lights...if so dose the one dash swich control both?.......2,in what order do you're rear lights work...i.e from top maybe stop ligh/ flasher then running light then reverse light? this dose sound daft but mine has been wired so that both top and mid light are on with runners and and amber bulb in the rev light hole to act as flasher and after market rev light under bumper but i have no rear fog at mobut im sure i can make a neat job of it by useing 1 of the running/flasher bulbs instead just need to know pattern pls
dogboy
uk typhoon
Re: rear lights
also been trying to find a wiring diagram not sure what you guys call it...a plan of all the wires and connectors can any one suggest how to get one please?
Daryl H
Re: rear lights
dogboy said:
can no one help with this? pls
The top light functions as the brake/turn signal lamp.
It also has another filament for dimmed night time parking lights.
The middle light is for parking lights only.
Bottom is for reverse lights only.
There are no reverse fog lights.....thankfully.
dogboy
uk typhoon
Re: rear lights
thanks for that guys will have to check it out.............dim parking light what ever next?
