Slyclone
Well-known member
Doing some routine matinence today on truck since I been racking up the miles.
I bought a couple of tubes of gear oil to put in the front and rear diff. I was able to jack the pass side and allow enough room for me to evac/dispence fluid. Remove plug, check level ( low) and add. I checked level with a bent piece of wire. It was pretty strait forward.
I figured it would be as easy to do the rear as it was front. So here I am.. Looking for a rubber fill plug or something g threaded to remove... Not seeing anything. So what's the work that is needed to be done here? Require a new gasket/removal of complete cover? Also how would you fill a stock rear of there is no plug/bung? Maybe I missed it. I'll crawl back under and look again. Service supplement says to check front/rear diff every 15,000 miles. I'm wondering if either have ever been checked.
