Rack and pinion. Plug and play
Quickstop [UK]
Combating adversyty.
Re: Rack and pinion. Plug and play
It says it's for 2WD. You could probably adapt it though. Would be a cool project.
bezerk
yeah, but what are the differences in 2wd and 4wd when it comes to everything? can see the driveshaft and axles beeing in the way. but i doubt a 2wd setup is that much different than ours as for steering parts and room?
Poconojoe
I talked to their tech guy at one of the Carlisle shows, he felt there was no way to fit it on a 4wd chassis. The guy also said if there were enough requests, they would consider making they for the 4wd if it could be done, but he had no idea of the number of requests or comitments that would be required to get the ball rolling.
bezerk
gonna make a quick geuss. if this set is close to fitment. the first set takes the same amount of labour as the cost of 1 set? so anyone intrested in a groupbuy than?
