R&R Engine ?
Sy#1991
Re: R&R Engine ?
And the engine will come over the front diff high enough without need to bend or remove line? Thanks
DanenGraham
Big in the rear
Re: R&R Engine ?
I had no issues with fuel line when I pulled my Ty engine.
Not the same fuel rail.
I had to bend mine but i was replaceing it and the return with braided line. You should be able to move it to the side enough to clear the block, you will need to disconect it from the trans??? I think the two lines are bolted to the trans case, unbolt them and you will be able to move them around.
Been to long, some one else should know for sure.
Re: R&R Engine ?
You will have to be a little more careful when you install the engine.
BTW Typhoons have a shorter fuel line. Syclone's have a front fuel rail connection, Typhoon's have a rear fuel connections.
