Question
sofaKINGfast
Im running 30pound injector pump gas and I was told that the turbo was 61. Do a need bigger injectors and a chip? Truck dosent feel like its at its best. I need some help.
Jimmy
Banned
You need Datamaster.I would imagine those 30's are way beyond maxxed out,considering the amount of air that 61 is pushing.
AlaskaTy
I second getting datamaster. But the most popular chip injector combo to go with is the Ultimate chip and 50# injectors.
AlaskaTy
It definitely could be. If your injectors are way too small you'll be running lean under boost and your ecm will pull the timing and the truck will fall on its face.
You need to get datamaster or find someone with datamaster, because if you're getting some serious knock (which you could be) you're on your way to blowing up your motor (sadly I know this from experience :( )
sofaKINGfast said:
Would this be the reason the truck takes off hard then stops pulling in second
It could be but my guess is something esle is your problem, the stock injector will suplly enough fuel to run low 12, high 11's. As everyone else said you need a scan tool of some sort.
