hvychy
I want to rebuild my engine on my Typhoon. Now, I just read that I could use a z block from another truck that is not turbo. It sounds great cause I can get one from the junk yard for like a $100.00 bucks or so. Now the heads are my only real concern meaning c/r . should I rebuild the bottom end and then put my heads on the other block or can I use the same heads? I also want to oversize the pistons and maybe lower compresion to run more boost. IS this a good Idea? I still have the stock turbo and of course will upgrade later. Thanks in advance for any help
