quad cab syclone
ketchme
ketchme
hi guys, im looking for some advise. i recently stumbled upon a syclone engine, harnes and ecm, (guy owed me money), anyway i have a newer S10 quad cab and had an idea. if i dropped the engine in what problems would i incounter. could this truck also be lowered and corvette rims installed. kind of a newer quad cab syclone. any thoughts, thanks...
sly dvl
Ya, it's got a Turbo
Re: quad cab syclone
Just off the top of my head, you're going from 1st gen to 2nd gen. so migrating the wiring will be a challenge. Not impossible, but a challenge. It's an interesting idea. I'm sure others will chime in.
It's just a six
Super Member
For smogging.
They go by the year of the car,not the engine year,not sure if you will pass smog ?
Do you need to smog test cars?
MRKING
New Parts for Old Trucks
With as cheap as sytys are these days , youd be better off selling the truck and motor and saving the headaches . You could take a reliable s-10 and turn it into a un-reliable clone real quick .
jpalmer
Ugh.it may be that i have had a bad day, and a "little" drunk but why bother. What is the the best thing that could happen? Un-reliable quad cab? If you really want to mod that truck, drop an 8 in it. not to discourage but just is not worth it. Maybe i just have had it with cat piss soaked houses and tired of bad ideas. dunno.
UK-Ty
Ty Crazy
Ugh.it may be that i have had a bad day, and a "little" drunk but why bother. What is the the best thing that could happen? Un-reliable quad cab?.
Yes but on the up side you could have 4 friends with you that could help push it unlike a Sy that only carries 1 :lol:
Having said that i do like the idea of a quad cab clone. It only becomes a waste of money when the owner of a project thinks so. Do your homework and if you think you can do it go for it, i for one would like to see it when its done.:tup:
UR50SLO
V6+2=LSXCamaro
What year is your quad cab? If it's 98 or newer then look at this thread I posted on FullThrottleV6.com
It'll guide you through the process.
http://www.fullthrottlev6.com/forum...ortec-Marine-Intake-Conversion-Helpfull-Hints
leadfoot
What year is the quad?
2WD or 4 WD?
All you need to do is transfer the exhaust manifolds and use the existing engine/PCM (if it is after 2001)
Then install the Edelbrock 2114 manifold welded for injector bungs. Switch over to air-air.
OR -You can use the sy manifold, but you have to modify it to fit the newer heads. :2cents:
