Project Time Attack - Random Images PCV System
HighPerformanceTrucks
Lift & Shift Specialist
main.php
main.php
main.php
main.php
All plumbed except I ran out of 3/8" hose to the intake pipe! I plumbed the fresh air intake 3/8" hose closer to the air filter and the dirty side feed PCV 3/8" hose while under boost closer to the turbo compressor inlet. There is a vacuum port on the Accufab 75mm throttle body that I plumbed in the dirty side feed PVC 3/8" hose while sucking under vacuum. Hope this works.
i8av8
Re: Project Time Attack - Random Images PCV System
looks great! i really like those black woven nylon hoses. something different compared to the steel braided hoses. been thinking of replacing mine with the black hose.
4C FED
Absolutum Dominium
They help keep the weight down. It gets expensive when you use the matching hard anodized black fittings. They are more $$ than the typical -an fittings.
Yes too much money like the rest of this money pit, but keeping weight down is important. I have over 20 feet of 12AN line for the oiling system alone!
i8av8
that's good to know :tup:
also, i just noticed the black bov. another cool looking accessory. i have the polished alum. one. same style.
0966Sy
Code what?
Adam, very nice setup. I was wondering on the passenger side tank where it T's into the can from the TB and Turbo compressor side. Are those fittings coming out of the blue Y block check valves of some type?
0966Sy
Code what?
I can not find those plastic npt/hose end pcv valves anywhere, Ive searched all over the internet. Can you point me in the right direction Adam?
