Re: Problem with Drive Axles??
The outside spins faster in relation to the inside. It has to it's on the outside of the arc. We're saying the same thing.
What does that mean, he didn't see anything? You mean like metal shavings?
I've never had to rebuild one myself but I but I'm sure someone on here has done one.
Here's what I found:
From the archives:
If you ever have the opportunity, try this test. Put the truck on a lift
or jackstands with all 4 wheels off the ground. Start the engine and put
it in gear so the wheels are spinning. CAREFULLY grab one rear wheel and
slow it down. As you slow one down, the other will speed up, to a point.
When the one you are slowing is almost stopped, you will feel the rear
lock and start to apply power to the one you are slowing. You won't be
able to hold it then.
Try it on the front wheels also and you will see the difference. The
front differential is open, and will not lock the opposite wheel. Also,
when you are done this test, shut the engine off and let the wheels stop
by themselves. If you hit the brakes, you will set an ABS code because
of the different wheel speeds.
Our rears lock by a governor in the differential, as opposed to a
limited slip posi that use friction cones to keep them somewhat locked
but allow some slip to go around turns. The limited slip additive you
put in those kind of differentials allows the slip. I've known people to
intentionally leave the additive out to get a better locking action for
racing. Our rear differentials do not need the additive at all because
they do not use the friction cone type posi.
Hope that explains it.
Jeff Richards
Then in the Helms I found this:
"Locks in turns"
Governor assembly tight in case.....free up governor
Broken or weak governor flyweight spring......replace the governor assembly and latching bracket
Flyweight in the governor assembly stuck...replace the governor assembly and latching bracket
Broken cam plate and or governor drive teeth....Replace the cam plate, governor assembly, and latching bracket
I tried to find some pics online of this stuff, but can't find anything but companies wanting to sell stuff. Sorry.
Hopefully someone can give some more info on this or corrections.
