Pre-Luber?
ghostrider_85
does anyone else have the pre-luber? for those of you that do not know, its a oil engine luber device that, prior to ignition, builds oil pressure in the engine for 30 seconds so as to avoid damage that occurs from "cold starts". the device also runs for 5 minutes after the engine is shut off so as to cool the engine and not damage parts. Since we run turbo application vehicles, the pre-luber also cools and lubricates the turbo.
I know that the company stands by their research, but my question is: for those of you that have the pre-luber, or have heard about it, whats you experiences/knowledge on this matter? I ask this, because it seems to really drain my battery prior to start up , and I really do not think I want to keep using it anymore if it is hurting my truck and not helping it...
warmpancakes
when I worked at gm we did testing on the item for the 6.2 liter diesels, they were great but tooo expensive for production
ghostrider_85
nah, more weight, just kidding...
i have a manual shut off switch on the truck so i have control over the use of the device. i wish i had the old paperwork and technical information so that i could post it here.
maybe i still do, i'll look for it thursday.
4C FED
Absolutum Dominium
I checked that stuff out before and was considering it.
But then I thought, since I went with a "dry-film lube" applied to all of the crank journals and bearings, it wouldn't be needed.
I still wouldn't mind having it to circulate oil through the turbo while it cools.
This here would be good in my case: http://www.granatellimotorsports.com/oilingsystem.htm
But it's way to expensive.
_________________
Rick
Sy#458
Galt, CA
<font size=-1>[ This Message was edited by: 4C FED on 2002-02-20 14:07 ]</font>
