Please help!
gwp78
I'm torn between putting 9.5" or 11" ZR1's on the back of the Clone. If I get the 9.5" with the 38mm offset and the 6.7" backspacing, will it look stupid without a spacer? And by getting the 11" does it correct the problem? I want to put 11", but I'm just curious about the 9.5". Also will the 16" x 8" ZR1 fit in the front without any spacers? I saw a Syclone with what appeared to be 16" in the front and 17" in the rear and it looked pretty cool. Please help :-?
TurboManiacal
1) Using a proper naming scheme that allows users to hone in on the item being discussed helps. For instance this topic I would name "ZR-1 Fitment Help" instead of a very generic "HELP PLEASE"
2) Don't know how the rims / tires would look stupid w/ spacers...
3) 9.5" rims rub inside left front when hard locked to the left.
4) 315's always look more wicked.
5) I've never seen the rims in 16" before...
6) If you run different size rims...take care to right size the tires because the overall height must match front to rear with the AWD system. If you run 16" w/ sidewall height of 35% and 17" rears w/ sidewall height of 35% you won't last more than 20 miles before you burn up your transfer case.
gwp78
Thanks for your help!
I had 16" x 8" ZR1's on my Camaro.
New to the AWD world. Didn't know.
Sorry for the generic topic. 0X
