PCV Routing
gmemony2
Found this today. Plugged hose running from passenger side PCV valve. I'm assuming this was originally run to part of the intake? Any reason other than this aftermarket intake you see in the pic that it would have been plugged?
neildemo
Administrator
Should be plumbed into the air Filter. There is a T on the passenger side Valve cover. Looks to be a RPM cold air Intake “I have a few”
gmemony2
Did the RPM cold air intakes not provide a fitting for this on the actual intake? Not real interested in trying to add in my own fitting/bung.
There's a small k&N filter on the driver side pcv which is why I'm assuming the passengers side is "capped".
neildemo
Administrator
no you need to get a barb and do it. You could also install a seperate Airfilter "Mini PCV Style" the purpose was to vent off fumes and reburn them into the intake I believe. The Double t and PCV work when under boost they close off and not in boost vents to atmosphere/intake. I believe I am accurate someone else can chime in if not.
