pcv problem "I HOPE"
ty#1366
just had new motor installed heads,cam,turbo,headers,intercooler,downpipe,etc. ive had the truck setting in my garage for about 3 weeks after getting it back while i relocated the battery and put on an airfilter i drove it yesterday for the first time and it has what looks like blow-by coming from the valve cover filter and now has oil leaks only has 50 miles since i got it back anybody have any ideas
Quickstop [UK]
Combating adversyty.
Re: pcv problem "I HOPE"
Do a comp test or leakdown to verify blowby. Are the valves plugged in the right way? Hope it's not serious.
ty#1366
the key word in your reply was valves it only has one i thought it had 2 when it was stock and i guess i was correct but now its just one i guess that could be the problem im going to go investigate
turbodig
PCVs don't *cause* blow-by generally, unless you have something hooked up really weird.
Could be oil or something burning off the manifolds?
Also important to remember - piston rings don't generally seal up instantly. Might take a bit of drive time
Take the oil fill cap off while running... if you have lots of lots of smoke/air coming out, I would give it a compression check. If it's just a minor amount of air, give it some time before condemning it.
One question I will bring up that nobody likes to hear- Did you fix the condition that caused the previous motor to go? A rebuild without fixing the underlying cause is a recipe for a second dead motor.
ty#1366
never really had a prob with the old motor, fuel pump went out and truck sat in the garage for 7 years just decided one day to send it to get every thing redone truck was at the builders for 2 1/2 years just got it back and now this im going to try to look at it more today when i get home
ty#1366
pulled dipstick and i could smell fuel so i changed oil and fuel smell was very strong and oil was thin anybody have any ideas
