Re: Passenger Exhaust manifold turbo studs
93ty475 said:
Anyone tried using bolts there? I tried a 3/8 header bolt....the ones with the small 7/16" head....The threads are the same, but there's too much side to side play as if they're not fat enough....Seems that the right bolt with a small head would be easier to work with being in such a tight area there around the exhaust housing...maybe there's an allen bolt out there that would work....
Yes, I did this and its been installed on the truck that Mark sold to Tim Barrett, you can install Allen socket bolts in there in place of the studs. They are a metric thread so not every place will have them but IMO, its a worthwhile modification. The removal of the bolts make it easier to yank the turbo off with out pulling the DP out of the way (Tims truck has a PTE kit on it, so this is a null issue but for stock turbo/dp trucks this is good move)..
Also, swapping to allen head bolts, makes it easier to remove them in the future with the corresponding socket and an extension on a ratchet
Studs are OK for the factory, they make it a PITA to pull off @ home tho..
I realize yer past this point, but Sears sells this for like $20-25 :
And they make them in different sizes and work very well. I wouldnt recommend using it on anything you plan on re-using (they beat up the threads).. Just giving you information for future issues involving stud removal if the double nut method doesnt work..
