Michael said:Does anyone have the part numbers handy for the Knock Sensor and its harness? I am getting false knock, and want to try the front-mounted sensor option (with its own wiring harness).
Thanks and regards,
Michael Pliska
92 Ty
That's what I was hoping to do. Doesn't the knock sensor have its own dedicated harness to the ECM (separate from the main harness)? IIRC, that is how it is represented in the manual. I was hoping to buy that "knock sensor harness" as well as a replacement knock sensor, so I could just make the connection at the ECM (and leave the original sensor & harness in place except for the connection at the ECM). Will this work? Anybody know what the part numbers are?SeattleSy#1255 said:one option is to disconnect the original one, buy a new one, install it and run it to the ECM.
Is that Wells number for the sensor or for the harness?VermontTy said:The "harness" is a single wire with knock sensor plug. Take your wire on the existing sensor and lengthen it. As for PN, the Wells number is SU169. Dunno what that might getcha in a GM part number interchange.
