PACKAGE DEAL- 2 truck and motors 650hp block
Injected1
I am selling off everyhting as a package deal, need the money very badly!
Box 1:
1) Lower radiator hose.
2) Collapsible spring hose.
3) EGR Solenoid
4) Pulley
5) Exhaust Clamps
6) Turbo coolant lines (feed & return)
7) Radiator overflow
8) Lower parking light
9) Turbo oil feed line
10) Motor mounts
11) Misc. heat shields
12) Steering shaft
13) Waste gate
14) Alternator
15) Accessory pulley
16) Accessory brackets
17) Thermostat gasket
18) Stock Syclone drive shaft
19) Stock Typhoon drive shaft
20) Front fan
21) Water pump
22) 2 Stock prop shafts
23) Misc. vacuum lines
Box 2;
1) Oil Dipstick w/ tube
2) Braided turbo feed line
3) Gas tank filler neck
4) Power steering pump w/ hoses
5) Battery hold down
6) 2 bar map sensor
7) Washer fluid res.
8) Fuse panel cover
9) Alternator
10) Injector Harness
11) Boost Solenoid
12) New fuel filter
13) Door vent
14) Idler Pulley
15) Ignition coil
16) Gas cap
17) Injector
18) Misc. vacuum lines & brackets
Box 3;
1 & 2) Distributors
3) Steering shaft
4,5,&6) OH-SHIT handles
7) Cladding piece for behind the drivers door
8 & 9) Fuel rails (with 4 injectors)
10) Gauge cluster harness
11) Misc. plastic hooks, push caps, covers & all interior screws
12) Air/Heat controls
13) Head & tail light controls
14) Cruise control
15) Alternator bracket
16) Throttle body
17) Metal turbo line
18) Upper intake
19) Braided turbo line
20 & 21) A/C compressors w/ brackets
22) Waste gate
23) Idler pulley & EGR valve
Box 4;
1) Typhoon wiring harness
2) Remote oil filter lines
3) Oil dipstick
4) Metal turbo coolant line
5) TV cable
6) Coolant return line
7) Cruise control
8) Alternator brackett
9) Lower intake w/ 6 injectors
10) Power sterring pump w/ line
11) Power steering pulley
12) Injector harness
13) Boost solenoid
Package 5;
1 & 2) Stock turbos
3) 20 G turbo
4) Power steering cooler
5) EGR
6 & 7) ECM's
8 & 9) Head gaskets (still in package)
10) Throttle body w/ push rods & misc gaskets
11) 6 Lunati rods
12) Upper inter cooler
13) 2 governors w/ calibration kit
14) Remote oil filter w/ lines
15) Red silicone vacuum line kit
16) EGR valve
17) Kenny Bell "Boost-A-Pump"
18) 4 bolt main Syclone block
19) 6 Injectors
20) Hood rod prop
21) 4 sets of spark plug wires (ATR, Autolite, MSD, & stock)
22) Sy/Ty part manual
23) Sy/Ty folder w/$20K & reciepts (not including $3600 Typhoon & $5500 Syclone)
Package 6;
1) 2 Corner lights
2) Flex plate
3 & 4) Crossover tubes w/ air boxes
5 & 6) TC inspection plates
7) Distributor cap
8) Stock FPR
9) Pulley
10) Inter cooler cover
11) Misc upper motor brackets
12) Washer fluid res.
13) Map pocket & arm rest for Typhoon
14) Typhoon over head console
15) PAS orange elbow
16) Throttle cable
Here are the trucks and their parts
Injected1 said:
Syclone pics before and after:
Typhoon pics in primer:
Let me know what you think.
Thanks, Nick
Typhoon rolling chassis - no interior w/ black wheels
Stock Sy long block and heads (sludge in motor & a bent valve)
Stock Ty Transmission w/ no governor
60K mile motor w/ 20 G turbo and silicone vacuum kit, poly motor mounts, EGR delete, PTE 3000s
Syclone possibly built transmission w/ transfer case
Syclone full rolling red chassis w/ rear disc brakes, new front clip and new grille, complete interior, and comes with 60% cladding.
BUILT MOTOR
SHORTBLOCK
Stock block bored .030 over- $300
TRw L2441 pistons with JE rings-- $450+$125
Upgraded rods- $180
Clevite bearings- $40
Comp 415 Cam--$260
ARP bolts- $30+$65
Lunati lifters-$215
Chromoly pushrods-$100
Edelbrock TC-$70
SFI billet harm. balancer-$225
SFI race flexplate- $95
HV oil pump-$115
I have $2500 in parts alone not including labor
LONGBLOCK
Vortec heads-$125,
Drilled-$150,
5 angle valve job/teflon seats/bronze guides-$225
ARP 3/8 rocker screw in studs-$70
Comp cam 1.6 Rocker-$260
Comp beehive springs-$250
Cometic Head Gaskets-$180
Ferra valves-$70
Lower intake modded for Vortecs-$400
ARP head bolts-$150
Various machine work-$475
I have $4855 in the longblock not including labor. Basically the same as:http://www.sytyperformance.com/inde...facturer_id=0&option=com_virtuemart&Itemid=26
I will take $2000 for the short----$4000 for the long OBO
I can probably ship this in the 48 for less than $150
This combo is easily capable of low-mid 10's w/74gtq and proper tune
ATR headers, ATR down pipe, and Sy/Ty 700R4 Race transmission, let me know i have a price in mind to go with the package deal.
IF ANYONE IS INTERESTED PLEASE CALL ME!
Thanks, Nick
850 642 7433
All parts are located in Destin, Fl.
Baythan
SY2TY2SY2TY
Re: Selling off everything...
:eek: That IS a ton of stuff.
Are you selling the boxes as "sets" or the contents of each box individually?
I'd recommend setting prices if the latter or you'll be back and forth with offers and counter offers.
Good luck!
Injected1
Good luck!
I will take $13,500 for the whole package. including everything pictured along with another stock longblock in great shape with no damage, just needs to be steam cleaned. I don't have pics of that one right now. Parts are for sale individually in the parts for sale forrum and the price will be lowered accordingly. I need all this gone!!
Thanks , Nick
Ry368
one mile = 5280 feet
Re: PACKAGE DEAL- 2 truck and motors 650hp block
[/QUOTE]
Hmmmmm....I'll give you a cal tomorrow if these are still around. Have any repairs been made to the headers and how's the coting holding up on the dp/headers(looks good in the pics..just thought I'd ask).
Injected1
where r u located?
ALL parts are located in Destin, FL and shipping is only the cost to ship 2 trucks that don't run. I think I will be able to load everything in the back of the Ty and Sy.
Thanks, Nick
Injected1
Hmmmmm....I'll give you a cal tomorrow if these are still around. Have any repairs been made to the headers and how's the coting holding up on the dp/headers(looks good in the pics..just thought I'd ask).[/QUOTE]
Injected1
[/QUOTE]
Please understand, im really not wanting to seperate any of the parts this is going as a package deal. but if you would like to pm me in the future we may be able to work something out. thanks - nick
clone 94
i would definitely be interested in a sy rolling chassis if you decide to separate. please PM me if you do
i could pick it up also
denny
The pic for the headers do not show the cross pipe, do you have the cross pipe?
QWERTYphoon
Motley Driver Award 2009
Interested in the headers and ATR downpipe. I am also interested in 18) 4 bolt main Syclone block from Package 5. I am also looking for an ash tray and a TC stall around 3000. Please PM me.
Thanks
Adam
Injected1
Everyone seems to be interested in the ATR headers & downpipe but no one wanted to pay what I think they are worth. So now I am selling it all together as a package deal as the title states. This package will only be available until Sunday 3-8-09, after that the whole package will be available on ebay. I apologize but I tried to sell it all individually but people were telling me they wouldn't pay more than $500 for these headers. I need 12K immediately so the package will have a starting bid of 10k and a reserve of 11, 500. If you are interested in the package please let me know. Once again the shipping is going to be the cost to ship 2 trucks.
Thanks, Nick
REVEREND HARMON
Party in a box!
Are the titles clear on the sy and ty? If i remember right , arnt they salvage titles?
:sly:
Injected1
Yes they are salvaged but I can get clear titles from Alambama.
Add up the prices of just the large items and you will see what a deal this is.
Enough for 3 motors one extremely built about $5000+$4000
3 transmissions one SytyPerforformance race 700r4 $2500+$500x2
ATR headers and downpipe $1500
And 2 trucks Sy comes with full interior and 60% cladding $1500each+1000
Don't forget $1000 worth of turbos
Come on guys dont let this get away!!!!!!
Luke
Fish sticks SUCK !!!
good luck with your sale on E-bay, be sure to post up a link for the auction....
Injected1
I'll come up with a reasonable, individual price list in the next few days - check parts for sale in a day or two.
Let me know if anyone is interested in either of the trucks. Thanks.
MikeRenz
not stock
thread cleaned up. Let injected1 sell his stuff the way he wants to. Carry on :tup:
clone 94
like i said i would be interested in a sy roller.
