Re: OUCH, have a bad sound coming from front end ---
i hope after all that front end work your shake is gone, i did the same, 4 ball joints ,4 tie rod ends, idler arm and pitman arm ,upper and lower control arm bushings , sway bar mounts ,four shocks ,balanced all my drive shaft and all new joints , new tires , new front hub and bearings....not to rain on your parade but my vibration is still there....
i had a problem once with a s-10 making a squeking noise almost sounded exactly like what your explaining. the mechanic replaced pads thinking wear indicactor , not it. replaced wheel bearings , not it.
i looked at the car (customer was gettin pissed ) ,it took me close to an hour and a half to find it, it was a squeak the got faster as the wheel speed increased. turned out to be the axle seal in the differential must have been dried out, i sprayed alittle wd-40 on it and noise went away , repalced both differential axle seals and noise was gone. not saying its your noise but that was one noise that was most definatly there but not easy to find.
