Sy229
Move with Purpose
that I got from Gary S. This one has an unknown history so we weren't sure what to expect inside. This was also the first time any of us have been inside a TC, so it was both a learning and a discovery expedition:
First up we counted up the number of spines (32) and figured that this was a Typhoon TC.
Other than a little surface rust from sitting around, most of the assemblies looked to be in good condition. The first thing we noticed was a loose pin on one of the planetary gears - it appears to have been sheared off and would likely be a driveability problem.
The second issue was the chain, which seemed to have a lot of play in it. None of the links looked damaged, so we're not sure if its in normal range or not.
George B., do you sell the planetaries? All: Any thoughts on what is an acceptable amount of travel for the chain? Is there any way to tell if the VC is working ok?
