Oil Restrictor
thehemi
I'm installing a Syclone turbo into my '99 S10.
I rebuilt the turbo myself (perhaps a bad idea)
and now that I got it running, I've hit a problem.
After a few minutes of operation, I'm getting oil
in the air intake tubing. Plenty of oil, not drops.
One buddy says I may simply need to install an
oil restrictor on the oil feed to limit the pressure.
(He also suggests that I check the oil drain line.)
Another buddy says I shouldn't need a restrictor
and that the turbo seals are probably toast.
Did factory Syclones come with an oil restrictor?
Or, indeed, is my turbo toast and need a rebuild?
(Which I will have professional done this time...)
Re: Oil Restrictor
No restrictor from factory, checking drain is an excellent piece of advice. Usually the oil will leak out the exhaust not the intake side though.
thehemi
Re: Oil Restrictor
Is the oil coming out of the intake a sign of anything?
I assume it wasn't going into the exhaust, but I guess
I can't guarantee that, though it wasn't like the exhaust
was spewing smoke (although maybe it wasn't hot yet).
mattw
Re: Oil Restrictor
True but the fitting that goes into the block has a pretty small opening(less than 1/8"). Also the stock braided oil feed line is pretty small. Proabably also less than 1/8" inside diameter. If he is running some huge oil feed line he could be trying to push way too much through it.
thehemi
Re: Oil Restrictor
I'm using -4 AN for my oil feed line. I think that is 1/4"?
Re: Oil Restrictor
I agree, but the oil coming out the intake side makes me think it is something else. I would guess something wrong with rebuild, or it was just bad before rebuild and not corrected.
Drain line NEEDS to be large and a straight shot, basically you have ~50psi coming in top of turbo, oil must gravity feed out the bottom, it should not be under any pressure to return to pan.
But I still am thinking a bad turbo.
thehemi
Re: Oil Restrictor
What's the best way to test the turbo oil drain line?
Pull it off the turbo and verify I can pour oil through?
thehemi
Re: Oil Restrictor
I must've had 10+ minutes on the engine/turbo while
it was stationary in my garage. It was only after I go
ahead and moved it out of the garage that it started to
show the signs of the leaking (gurgling).
I'm not sure if this is coincidence or if there's a chance
that finally putting load on the engine caused it to make
the issue even more problematic than it was previously?
Maybe I should clean it out and idle it again to see if it
decides to flow more oil again...
jwaller
Evil Genius/SyTy Guru
Re: Oil Restrictor
you didn't rebuild the turbo the right way. take it off and have somebody that knows how do it for you.
thehemi
Re: Oil Restrictor
Fresh turbo rebuild or not, can I still use my -4 AN oil feed line?
I know someone who runs it and says its fine. But it sounds like
-4 AN is quite a bit larger than the stock oil feed line?
