Oil pump?
luisdial1
What oil pump are you syty people using with a stock oil pan? I currently have a m155 pump with a 3/4 pick up tube. Stock volume ,stock pressure. Don't want to use the 5/8 pick up/pump. Pick up to pan clearance is more the 1/2 inch with oil pan gasket. With out gasket I'm a little under 1/2. I'm trying to be 1/4 to 3/8 clearance from what I read online.
Example Picture from online. 5/8 and 3/4
luisdial1
Thanks for the reply. Came across these post's. Unless you used the stock 5/8 pick up with pump(M55). You are going to have a slight bigger gap from pickup to pan clerance. According to DaveP, 1/2 clerance is no big deal when using the M155 pump and 3/4 pick up.
