WHAT????
Millions of heavy duty over the road diesel trucks, locomotives, marine vessels, and off road mining and construction equipment run millions and millions of miles and hours on Dino oil every year. (Virtually all diesel engines are turbocharged). Many go 10's of thousands of miles or hours between changes as well. And they don't run "Synthetic" oil. Reliability is everything to the owners of these engines. If turbos were failing because of running non-synthetic oil, they would change, and we would know about it.
And WTF is "Synthetic" oil anyway? Research it. I have. It comes from the same crude oil that Dino oil comes from, but originally (origional Mobile 1) was refined from Base IV & V stocks. After Mobile lost the law suit against Castrol (which was using Base III stocks, and calling it "Synthetic"), all mfgs reverted to using Base III (cheaper) stocks and calling it "Synthetic". Including Mobile. "Synthetic" oil IS 'regular' oil. Just costs more. Mobile 1 used to be better, but now it's just "motor oil".
It's the additive package in the oil that prevents wear, foaming, and coking that affects turbo life. Not the description on the container the oil comes out of.
Your blanket statement that "turbo cars & truck must use Synthetic oil for turbo life" is BS. More accurately: Turbocharged engines must use an oil suitable for turbocharged engines.
