White97SVT
ughh, so the truck wont start....I had it parked for the winter like always and now nothing. I had it started a few times and drove it up and down the street a few times when there wasn't any sand on the roads and I had it just at idle in the driveway for a little bit while I worked on the STi and now I go to start it and nothing.
Before I put it away for the winter on the last drive I noticed it was running a little funny kinda like having a stutter and then it would smooth out and then stutter again. It was fine at idle, only when I would get on the gas. But didn't think much of it till now. (I planned on a tune up this spring before driving)
Checked the battery and the charge is good there. I used a spark tester and it shows me getting spark, but I got nothing. When I click the key to on and watch my FP gauge (DEFI) it does the test and then just sits at 0, it used to sit at 40psi when I would start it.
So I changed the fuel filter thinking that would might be clogged. When the filter was disconnected I turned the Key to On figuring if the pump primed I would get fuel out the line. I got nothing...so I tried to crank it for a couple seconds and still didn't get any fuel out the open line.
So guys need a little help on this one. Where should I start? Fuel pump relay? Ign module? fuel pump? Some fuse I don't know about?
I appreciate the help as always, Thanks.
