gjp
another post whore
found this while surfing. Says you dont need a computer for this 80E. Also you can buy a case for a direct swap with a 700r4. Anyone heard of this. http://www.transmissioncenter.net/4L80E.htm
2006 - 4L80E in C4 Corvette Adapter Kit (1984 - 1996). Swap your 700R4 / 4L60E transmission to the much stronger 4L80E transmission with our new double strength case hardened output shaft and adapter kit. At this time we have in development an adapter kit for the C4 Corvette to replace your 700R4 / 4L60E transmission with the much stronger 4L80E transmission. This 4L80E transmission will be the same length as your 700R4 / 4L60E transmission making it possible to reuse your existing 27 spline driveshaft and C-beam. This is the worlds first 700R4 / 4L60E to 4L80E swap direct replacement. All that needs to be changed on the 4L80E transmission is the tail housing and output shaft. The full manual shift model works without a computer. www.transmissioncenter.net/4L80E.htm
