asrnj77
..hard to swallow
So as I mentioned in another post I did some basic maintenance stuff...new cap/rotor, plugs, wires, harmonic balancer, tcc solenoid, fuel pump relay, heater core, engine tie down, rewired intercooler pump and flush system...It ran fine for a while...
Recently its been running grumpy..with a kind of low idle. Ran the DM and was getting knock at WOT also some DTC errors but I can't seem to pull anything up on it to tell me what the codes are. When I first put the key in the on position the check gauges light continues to flash and the truck makes a loud noise like a fuel pump x 10. Its fine once I turn it over all the way but I don't remember it doing this previously. I have a big box o'upgrades waiting including the important fp upgrades, afpr, alky, and wideband. However I need to get it running right again before I proceed. Any ideas? DM file below..it's a little bit long...I did a ride from my garage down the highway. You'll see the intermitent error light pop up
http://www.mediafire.com/file/gzmmfu...ew_turbo_2.uni
