GEMELLI
The Best of Both Worlds
After more than 3 years of Typhoon ownership, I've finally come across a problem I can't figure out with the search function. I've been member of this forum for a few years, and it has helped me tremendously. Thank you all for that! I'm no professional mechanic, but I can turn wrenches when I have to, so here we go.
I only drive my Ty two or three times a month, and it ran just fine a few days ago when I drove it into town and back. I went to start it yesterday, and it just cranked. I can hear the pump kicking on and priming the system. It had been a while since I replaced the fuel filter, so I did that. Does the same thing. I don't smell fuel on the dipstick or in the fuel pressure regulator's vacuum hose, so I believe the fpr is ok. I hooked a fuel gauge to the test valve and these are the results: Key on engine off, approx 40 psi. Cranking, just under 50 psi. After I stop cranking, it immediately starts to bleed down to 22 psi and holds. I can start it with starting fluid. I've done it a few times, and half the times it has started and idled just fine, driven down my driveway, up to about 15 mph. The other half, it will die as soon as I give it much throttle. This morning, it started right up, but once I shut it off, it wouldn't start again.
There is a CEL when it's running, but I haven't checked it yet. I will now.
I believe it was completely stock when I bought it, so other than a few suspension and appearance mods, it still is.
Thank you for any help I can get!
