Quickstop [UK]
Combating adversyty.
OK, truck was running the other night then it just died.
I have checked all the plugs and they were fouled so I cleaned them and put them right back in.
I have put in 2 gallons of gas so that's good.
Weirdly, the fuel relay seems to have died so I had to jump it. I can hear the Walbro running well. So the relay is good but why won't the ECM turn it on?
ECM is good - I get code 12 and the ALDL feed works. The Ostrich is seated and has no problems connecting with the truck/TunerPro and I can see battery voltage (I have a start cart), RPM, MAP, TPS and AFR. All telemetry is good.
I checked the ECM fuses and they are also good.
I replaced the IGN module thinking it might have failed.
I have just put a timing gun on it and tried to start it but got no timing from the gun. An HT lead directly to a sparkplug on the alt showed no spark there either.
What am i missing?
Coil?
I tried to find chart C-4 (HEI cicuit) in the supplement/Light Truck PDF but couldn't seem to find it. Any pointers?
Anyone out there have any ideas please?
Bloody truck - always fighting me!
What am i missing?
Coil?
