I've been trying to get my Typhoon to fire for the past 2 weeks with no luck. It turns over fine, I have fuel but no spark. I pulled the truck in to my garage almost 2 years ago to update a lot of stuff and when I pulled it in, everything was running fine. I've searched the forum and have found very similar problems and I have tried a lot of the suggestions from those threads with no luck. The best we can tell is the coil is not getting a signal to fire. Here is a list of new items and things we have tried>
New parts:
Accel Billet distributor
MSD coil
Plug wires
plugs
starter
battery
Here's what I have tested or tried:
Double checked all grounds (took them apart and cleaned them)
I have checked all fuses
I have a spare control module that we tried
Took both control modules to parts store and had them tested...they were fine
Put new cap and rotor on (the cap on the new distributor had a loose coil wire terminal)
I replaced the pick up in the distributor
I have tried a second coil
I am getting 12 volts in to the coil, both sides (pink and white wire)
I am getting 12 volts from the coil in to the control module, both sides
I have checked the harness from the coil to the control module for continuity, tested fine
I have replaced both terminals that connect to the coil (they were looking a little rough)
I have tested and checked the pink and white wire coming from the main harness to the coil, I followed these wires as far in to the harness as I could looking for damage, none found. We did a continuity test on the white and pink wires to the gauge cluster, the white wire had 0 ohms but the pink wire had 81 ohms (does anybody know what this should be?)
I have checked for continuity on the 4 wire harness going from the control module to the ECM, they test fine
Ohm tested the coil wire, tested fine
Ohm tested plug wires, tested fine
We tested the injector harness to see if it was firing the injectors while turning over and they are getting a signal.
I took the ECM apart to veiw the board, checking for obvoius damage and nothing was found.
There are no codes stored in the computer
The check engine light is coming on when key is turned to the on position
The only thing I have not changed is the ECM and the chip but I hate to buy a ECM not knowing that this is the problem.
Does anybody have any suggestions or is there anybody in the Coulmbus Ohio area with a computer and/or chip that I can borrow to see if it fires?
Thanks for your help guys
New parts:
MSD coil
Plug wires
plugs
starter
battery
