No propshaft racing results
Re: No propshaft racing results
So this raises another question I have. Is it okay to dyno tune one of these trucks with the propshaft out? I would assume so since people have driven them down the 1320' without damage.
Any opinions?
It's just a six
Super Member
I did about six dyno runs,, averaged 550 ft lbs of torque. No propshaft.
No problems.
100% stock untouched longblock.
Nova67ss
We did a dynorun (sceduled 3) on Roberts Bad Ass when we where ther and also this without propshaft, thats worked out good BUT the problem was to get the engine the airflow it needed so the temp would be stabel in safe level.. THAT was a major problem for us that day (hot) and the hurricane fans they got did´nt managed this so it was canseled after the first test run.. on low boost
alwayscode390
pppssssshhhhhtttttttttttt
I wouldnt dyno tune on one ... I mean the engine is seeing a different load.
I wouldnt hesitate to dyno RUN one though ... I would guess you would see a higher hp without the extra load :) ---
NecroWolf
lost marbles member
so i managed a 14.2 with no front shaft and before i realized my inter cooler wasn't working. damn i wish i'd made it to the track after i fixed those cause i'm pretty sure i could have clicked off some killer times and that f^cking lightning wouldn't have beat me.
tnsyty
You think RWD is bad, try FWD. I had my main drive shaft out when I first bought the Ty to replace the Ujoint. Just for kicks I took a very short spin. It will break the front tires loose at basically any speed. If it downshifts while in boost, you get a good smoke show. AWD is the way to go.
NecroWolf
lost marbles member
that just sounds too funny, i might have to try it once
