aasltmike
Got in the Ty this morning to go to work and cranked the engine. It started turning over briefly then died with dash lights and dome lights on. Turned the key to the off position and went to crank again and nothing lit up! :rant: No dash lights, no ignition beep, the alarm did not go off, no dome lights. Checked my connections at the battery and checked fuses in the fuse panel. All fuses are good, cables between the battery, ground, alternator and starter are good and no blown fuses. Used the multimeter on the battery and it's showing 12.3 volts. Anyone have a troubleshooting logic tree for no power, no start? Hints on where to start?
