No potential at ELC fuse location??
Lamotta81
I wanted to replace my rear shocks with monroe air maxs and tried to see if the compressor functioned low and behold it doesn't. Being the "whiz" that i am i checked for volts at the fuse terminals nothing.... i tapped the left terminal and jumped it to a different terminal and recieved -12. The right terminal with the same approach yielded nada... Any comments are appreciated 0X Also ive found an orange wire that is suspect coming into the truck likes to fluctuate read almost 5 volts wiggling it vigourously, Is there any way I could splice into another circuit behind the fuse box so that my suspension will work??
