During the last few days I did some work on my Ty. Today I went to start her up and nothing. The lights in the cab wouldn't even turn on. Here's a quick review of what I did.
Day 1: I pulled the battery and simple greened/cleaned the engine. Let it dry for the day (battery still out), The next day changed plugs (NGK UR6), wires (Taylor), dist. cap 'n rotor (Conrad) and Ian's vacuum kit. The following day I did the shocks (pulled the ELC unit), took off the door panels (will be changing the window motosr). Today I did the IC pump (Shurflo) and hose reroute. Next I put the battery back it. Opened the door to connect A/B on the ALDL to bleed the IC system, turned the key and ....nothing. NO power. I checked the fuses...all good. So I popped a battery charger and let it go for bout an hour. Came back. Still nothing. Lights won't light everything electrical is dead. I will be leaving the charger on overnight.
My concern is that with the battery charger connected and I open the door I still don't get any power. Wouldn't they still light even if my battery was completely dead because I have the aux power hooked up?
How should I troubleshoot this??? Could I possible have shorted the system somewhere??? Maybe I cut a wire??? What should I buy that could help in diagnosing this???
Thanks,
dcwik
Thanks,
dcwik
