bdubb said:
does it have a cat?
what gauge are you reading?
what boost to you get when unplug the weather pack connector on the solinoid?
does your wastegate arm move freely?
have you adjusted the wastegate arm?
and so on and so on.
For once he's not being an ass, so listen...
If it has a modified exhaust, the turbo faces less backpressure, so the undersized wastegate becomes even less effective.
If you're reading the stock gauge, don't. Mine's pretty close overall, but just today it was maxed out when I was only at 10psi in reality.
When you unplug the wastegate solenoid's electical connector, it won't modify the boost signal at all. Like that it should get base boost, around 8-10psi.
Probably not an issue with new parts, but if the arm doesn't move... well... it's not going to work right.
If it's not adjusted properly, your boost will be wacky. I think this is even more of an issue if everything was just replaced. There are details around somewhere, but I can't find them. You want the arm to overlap by 1/2 to 7/8 though, by the service manual.
