Nitrous help
Turbo6
10.20@131.8
Re: Nitrous help
sy2270 said:
Does anyone here know if anyone make a nitrous kit for our trucks?
Thanks
Get a universal single fogger kit for fuel injected vehicles. After you get it installed I'll help you with jetting decisions.
TYHOGG
Re: Nitrous help
Turbo6; I have a nx express kit. single "shark" nozzle for gm efi (took off my wreked s-10). What would you recomend as jetting selections, I have a PI 2800 stall going in, but in the mean time i would like it to spool a little quicker. Possibly a 35 shot?
Turbo6
10.20@131.8
Re: Nitrous help
I have my list at home tha I used so I'll have to let you knkow tonight. What fuel pressure are you running?
TYHOGG
Re: Nitrous help
Right now i'm running 40lbs with the vac attached (for ultimate chip).
Turbo6
10.20@131.8
Re: Nitrous help
GreenTyGuy said:
Turbo6; did you ever find those jet numbers?
Forgot....I will look later tonight and get back with you. Sometimes you gotta keep reminding me. I have CRS.
Turbo6
10.20@131.8
Re: Nitrous help
OK I found the info. When I ran the 10.93 I used a .033" nitrous jet and a .020" fuel jet. That was at 45 psi fuel pressure. You may want to start with a .033-.034 nitrous jet and a .021-.022 fuel jet and if its rich work your way down with the fuel jet. It should give you about 40 hp or around 3-4 mph. Dont expect it to change the et a whole bunch.
Turbo6
10.20@131.8
Re: Nitrous help
I said nitrous jet where I should have said fuel jet. Fixed it so should make since now.
