Newbie - Needs new Turbo Coolant Return Line!
Motokal
Ok guys.... Newbie needs new turbo coolant return line.
Any ideas on where I can get a new one?? ...the Dealer says its discontinued.
_________________
Kent
Phoenix
Sy 1793
<font size=-1>[ This Message was edited by: Motokal on 2002-04-08 17:12 ]</font>
RAACCR
Yeah...it seems like most of the turbo lines are discontinued by GMC. You're looking for the line that returns coolant from the turbo to the passenger side of the block? I think I've got one or two of 'em down at my warehouse...I'll check it out for you. Otherwise, if you can't find an original, you'll probably have to make up something custom.
Rob
_________________
This Sy has killed before...literally. Anybody else want a ride?
<font size=-1>[ This Message was edited by: RAACCR on 2002-04-08 22:18 ]</font>
Motokal
RAACCR
Yeah, thats the one...cracked/split at the last bend. Let me know if you find one and would be willing to part with it.
92Typhn
Are you looking for the hard lines? Cause if you are, and a Typhoons are the same I will go dig the ones i got with my truck out and look at them for you
Motokal
92Typhn,
Yesss! The I am looking to replace the hard line coolant return line.
However, I don't know if Ty's use the same line or not.
Does anybody else know?
Wes
Yeah, I'm in AZ. There's a few other Phoenix guys on the board too. How long have you had your truck?
On 2002-04-09 12:13, Motokal wrote:
Wes,
Yes, I am in AZ. You?
-Kent
RAACCR
The coolant return lines are universal to both Syclone & Typhoon applications, and they are confirmed to be discontinued by GM. I have one complete (upper & lower tubes with a new flexible rubber center section), and another with good lower & rubber sections, but the banjo end has been cut off of the top tube.
Let me know if you still need one.
Rob
syclonerob@prodigy.net
tealty
If you still need it, I have one that I pulled off my old sy or ty, I cant remember which one. But anyways, I dont have the bolt that goes through the banjo fitting, but everything else is intact, except for the rubber hose that connects it to the bottom fitting on the engine block, you would have to fix that part since its cut in.
Motokal
Tealty,
Yes, I still need one. I am interested in the complete one....How much do you want for it?
Can you send me an email, prolly easier.
Thanks
