New PB 11.22 @121!!!!!
Sean Krupa
Moderator
Re: New PB 11.44 @121!!!!!
Goin back to the Track next weekend. We shall see what she does. I fixed the Slow Building Boost issue and should solve the Launch/60'. Also, will probably try manually shifting it for the 2-3 shift to 5,500 rpm.
I'll keep you guys updated!!
atkonkler
Is this your bush?
Congrats Sean.....good luck next time at the track! Get it even lower....hopefully now that it's cooler out you can utilize the dense air more!
Sean Krupa
Moderator
Heading out to the Track at 8am. Will update the post ASAP. Wish me luck!!
Sean Krupa
Moderator
Re: New PB 11.22 @121!!!!!
Ran a new Best today. 11.22 @121mph. Had to tweak the Rear adjustable shocks a bit due to it spinning bad the first couple passes. It was squatting too much. Went from a 1.7 to a 1.5 60'.
Went with my buddy with a Big Turbo 20th anniversary GTI which has like 350+hp. He had some issues with his blowing off the Vac line and overboosted. Luckily the motor was safe but took out 3 spark plugs. He had extras and we both drove home safely.
I drove the Ty to the Track this time which is an hour. Made 5 passes then decided it was enough for the stock bottom end. Videos will be up shortly!! :turbo:
Sean Krupa
Moderator
Cool that the Announcer said my Name and where I'm from. At first he said it was a Syclone but corrected himself and said Typhoon haha.
Awesome. Your typhoon is running better times than I would have expected.
How much boost & timing are you running?
nastety92
Nice run Sean. The improvement in the 60' foot time seemed to be key.
Did they bother you at the track for not having a cage?
