New member Canada Alberta
Dgloss69
Hi iam a new member this is my second ty ive owned first one got stolen and wrote off. Ive started upgrading just waiting for the time I need to get all the parts installed properly. Im starting off with ic upgrade to Johnson pump and heater hose for lines. New plugs wires rotor cap all from rpm. Ic shroud 160 t stat brake booster line with turbo fitting rpm cold air intake walbro 255l fuel pump with hot wire/ic hot wire then its going to Nolan for a tune and a chip.some of the work is already done but I still have a ways to go I hope everything goes good if anyone has any suggestions im open to them.
CalgarySS
1000 miles and counting..
Re: New member Canada Alberta
Sylvan lake? I am sure I will see you around. I will be pulling the cover off of my truck next weekend.
choffert1
Welcome. Glad to see another member from Alberta. If you go to track sometime I hope to see you there
Matt
LS motor swaps is the reason they made the jimmy or blazer don't wreck a Typhoon
Dgloss69
I got jack stands and she's been up in the air for two months now I'm always working and just don't have time to finish what I started might have to book some time off before I forget where everything goes. I should have it ready for thunder in the valley this year.
choffert1
If you are coming down to Drayton Valley for Thunder in the Valley. it will be good to see you there. I hope to have my sy there. lmk if you are coming down so we can meet up.
Dgloss69
I will let you know im just waiting to see if Nolan from Moretto in Edmonton can tune my truck or if I need to get a chip from turbo tweak.
