New guy with problems 93 ty #0615
369fox
ok i bought a black on black ty 93 #0615 i bought it off ebay and guy said mech its a 9.5 out of ten truck looks good but run at like a six and the move was from IL to FL so would that be a problem....here is a list of mods he gave me thanks
Engine and trans professionally rebuilt fall of 2004 at 112,189K miles. Larger Pistons on engine .030 over otherwise stock. Trans upgraded with beefier components than stock.
Exhaust system upgraded. Exhaust ATR stainless and highflow cat converter 3" back from turbo. Stock pipe only 2.5"
Tubo upgraded to Garret turbo installed by Rockford Racecraft.
Suspension- Bilstein Sport shocks installed. Addco rear sway bar added,
ATR air induction system with cone style high flow air filter.
Intercooler mega pump installed. They put this kind on RV's and its flows 10 times better than stock and runs full time. Stock only turns on at certain temp.
Original Sy/Ty mod intercooler upgrade. Extra Hayden radiator added to cool intake air to engine.
Alternator, Starter, Serpentine belt, water pump, Upper and lower ball joints, Idler arm and pitman arm also replaced.
All wheels professional remanufactured and powder coated black. They look new except for a few paint chips easily touched up.
Viper alarm with remote start / Alpine cd player
STG 13 in 1 performance chip, A-piler w/Boost guage and chip controller, manual boost controller eliminates boost creep,
255LPR fuel pump, stock pump sucks. Can adjust Chip to boost 15psi -22psi stock is only 14.5psi. Programs to change ignition timing too.
relocated battery to cargo bay to accomodate larger turbo.
SBNova
Re: New guy with problems 93 ty #0615
I think your gonna have to describe what is wrong before anyone will be able to help you.
SYO237
SyTy Registry
Where in FL are you moving to? Once you describe the actually prob your having as SBNova referrenced, there maybe someone in the area to come over and help you diagnose the prob.
369fox
ive been toying with it all morning and ive come to the conclusion that it is my throttle response that is slow going at thirty down highway and getting on it a little it works fun but this is an awd and it does not come off the line harder than my camaro.
the guy told me to call guy at rockford racing in ill he is the one that built the truck and tuned and set it all up so he thinks that i have a slight fuel issue so im ganna call today later thanks
also im in jacksonville fl and am wondering if anyone else is close to me just to know...
I recognize the 13 in 1 chip :lol: , its probably 16 program or a 10 in 1. So much for a 12 sec truck...
http://cgi.ebay.com/ebaymotors/GMC-...iewItemQQcategoryZ6248QQitemZ4627984893QQrdZ1
Before you go to crazy with understand your chip, T1 timing is for pump gas, the higher numbers are for race gas (and/or if using alky). Boost, you also want to keep that down to 15-17lbs on pump gas.
If it doesn't come of the line hard than Camaro (unless its running slicks) something is wrong. You need to get or have access to a scan tool and figure out the problems. Get in contact with the local SyTy owners, they will help you far more than you will ever get from contacting long distance a shop (especially since you didn't buy the parts from them). The shop is probably want to see scan tool readings anyways...
369fox
i dont have a scan tool ...
i know it is not a 12 second truck but once it spools up it is good im only running 17 psi on the t1 setting ive read through the chip description and i get it... but im wondering if the climate change will affect things
mattw
OK, I just read all of this and I can't help but wonder if you are launching this thing or just flooring it off the line and expecting it to instantly spool and rip away? If you don't build boost against the brakes and leave the line with a few pounds of boost it won't take off quicker than a camaro...
-Matt
369fox
i have launched the truck and it was better, but it just doesnt put you back... im new to all this but am reading up and toying with the truck all the time...
Jimmy
Banned
Interesting carfax on your truck.It was registered as a diplomatic vehicle at one time.
01/15/1993 New York
Motor Vehicle Dept.
Lockport, NY
Registered as
corporate fleet vehicle
02/21/1993 10 New York
Motor Vehicle Dept.
Title issued or updated
First owner reported
07/07/1994 4,060 Virginia
Inspection Station
Fairfax, VA
Passed emissions inspection
07/25/1994 U.S. State Department
Great Falls, VA
Registered as a diplomatic vehicle
10/01/1997 U.S. State Department
Washington, DC
10/03/1998 52,000 Virginia
Motor Vehicle Dept.
Lorton, VA
Title or registration issued
10/03/1998 52,268 Virginia
Inspection Station
Woodbridge, VA
10/23/2000 76,346 Virginia
Inspection Station
Woodbridge, VA
10/27/2000 Virginia
Motor Vehicle Dept.
Lorton, VA
05/14/2001 83,280 Service Facility
Vehicle serviced
Lubed oil and filter changed
12/21/2001 87,453 Virginia
Inspection Station
Fairfax, VA
12/28/2001 Virginia
Motor Vehicle Dept.
Lorton, VA
10/08/2002 Virginia
Motor Vehicle Dept.
Lorton, VA
06/20/2003 102,083 Service Facility
Vehicle serviced
01/09/2004 Virginia
Motor Vehicle Dept.
Lorton, VA
New owner reported
01/09/2004 105,687 Virginia
Inspection Station
Lorton, VA
05/14/2004 Illinois
Motor Vehicle Dept.
Glenview, IL
Title #T4135671477
Exempt from odometer reporting
08/25/2005 119,000 Illinois
Inspection Station
Skokie, IL
