turbojimmy
Hose came off the turbo. Duh. That explains alot. Still doesn't explain why I have to adjust the valve all the time, but at least it's not broken.
Original post:
I have the POV that Russ Bland is using. Got it from the nice folks in the UK. Every time the weather changes, I have to adjust it. Today is the last straw.
It's in the teens here in scenic NJ, and I'm driving to work noticing that the POV is making lots of noise today. Check the boost gauge - the frickin thing is venting pretty much all of my boost. I figured that as things got warm under the hood, it would be fine. Nope - after a 40 minute drive it was still doing the same thing.
Why would it behave differently in the cold? Wouldn't the spring actually be stiffer? Is there anything I can do about it? I may just yank it and goof around with the wastegate some more (I installed it because it was over boosting).
TIA,
Jim
_________________
1992 GMC Typhoon: Stock, 13.7 @ 96
1987 GN: PT51, PTE 50#, Jim Testa chip, 100# valve springs, THDP, TT 3" duals, Walboro 340 hot-wired, Level 10 trans/TC
http://www.jimmyz.net
<font size=-1>[ This Message was edited by: turbojimmy on 2001-12-31 14:43 ]</font>
Original post:
TIA,
Jim
_________________
