Need some ideas on engine behavior
George Blake
DONATING MEMBER
During cold weather, the engine has to crank and crank to start.
Shakes like a mother.
During warm weather. One thunk and it fires right up and runs a LOT smoother than in cold weather. I did the EGR delete but haven't done the prom change to disable it. No codes. It's got new plugs. Old wires and cap. Could that take care of it? I also deleted the cruise control and the vac ball. I used the chart on the fan shroud so as not to miss anything and replaced all the vac lines.
turbodig
Re: Need some ideas on engine behavior
Stock chip?
Fuel pressure is ?
Big vacuum leak would be my first instinct... engine heats up, parts expand, seal the leak.
Maybe the intake gasket?
George Blake
DONATING MEMBER
turbodig said:
Stock chip?
Fuel pressure is ?
I've gotta go through the whole thing to get current but AFPR is 45 PSI. Stock chip.
I know my alternator is bad. I'm gonna swap it out to the new unit and then do cap and wires. I bet I've got a vac leak. Upper intake and lower intake have never been off.
WyoSyclone
...wonder if the IAC valve is operating like it should. Does it idle fast during a cold start? If the IAC is stuck, or not moving enough to raise rpm's during a cold start maybe it's running way rich at startup??
Syclone #1721
I LOVE 4UM SUPERSTARS
I vote for the vac leak on the lower intake. Mine ran very much like you are describing before I changed it out.
Syclone#892
Bad coolant temp sensor? Sensor could be showing wrong temp and causing a problem, i've seen it on plenty other vehicles so I wouldn't doubt on a 16 yr old vehicle that it could be bad. Plus they are cheap enough to replace just because of its age. Good luck on what you find.
