Need help!
sytyfreak
Hi all,
I used the truck this morning to go to college. The truck ran "normal" on it's way to college. I came back from college and the truck was running like always. I stopped to chat a bit with some friends leaving the truck in park and on idle. When I decided to go home I switch to OD and the truck just died on me. I put it back in parking, and it started like nothing had happended. Then I switched back to drive and died again. I turned it on once more and this time I gave it a little gas and I got home which was about a street ahead. I left the truck on idle, in parking and gave it a copule of revs and it began having problems and struggling to almost when it went past 3,500 rpm. I did it twice and turned it off.
What could this be?? Is my fuel pump going to die anytime soon?? this is mi only guess... The truck seemed to struggle a bit also when I gave it some throttle when changing lanes, but it would be just a bit and then it just acted normally. Please I need some advice.
Thanx!
InvisiBill
The fuel filter on my S-10 got so clogged that the truck would sputter when I got on it. If you haven't changed that lately, it's a lot easier and cheaper than a fuel pump...
