Need help! whats the best solution?
Breth
Hi all!
I run a complete stock typhoon.
My plan is to put the boost a bit higher, and later put a bigger turbo with a 3" exhaust on it. I have already (not installed but in my garage) a 255 walbro pump, a fuel pressure regulator, a blow off valve, a high flow catalyzer and big air to air intercooler.
My goal are 400hp.
I read a lot complicate stuff about a lot of difrent chips.
So my question what is the best solution?
Code59?? Have sombody experience with this code 59??
Best regards Breth
SY2455
70's Veteran
Re: Need help! whats the best solution?
Welcome to the site. You better start a transmission fund, you will need it. You need to get the tuning and data logging tools so you can see what is going on with your engine before you get too carried away with it.
Read up here http://www.code59.org/
Before you jump in a do that list of mods, I would suggest you study and get it running properly as it sits, stock.
Research and patience will be your best friend with these trucks.
Breth
I know that there is more than only those mods i listed. But i only wanna know about the enginestuff wich is much different as all the japanese cars. I worked in a shop where we built 1000+ HP Supras, Ferarris, Turbo Volvo`s etc, etc. I have a lot of experience in fabrication of complete turbo setups (aluminum welding, stainless steel welding, etc.)
So i was also driver for 3 seasons in the erbacher drag-race team (runs in the nhra now). So i have enought experience about transmission and everything what i need else.
But on the Typhoon a lot of stuff is diffrent as on other cars i worked with.... i read a lot about the typhoon and about tuning the car before i was buying the car. But i dont wanna make anything wrong (there are so much diffrent shops with chips, and guys who killed their engines).
Best regards Breth
SCWolverine
As far as the "study" part goes, get your hands on the P4 document, and a LOT of caffeine. After a little reading here and on 59.org it'll become obvious who the "big brains" are, follow them.
