Need Help! Fog Light Wiring///Problem Fixed////
ViciousV6
400HP/550FTLB
I am trying to rewire my Fog Lights since my harness was cut out of truck and i have Big Stuff 3 Unit the fog lights have never worked. The use to. The harness off the lights have a Dark Purple with white strip wire and trying to figure where that attaches to for the light switch.
I don't see anything on the schematic for wiring about fog light wiring.
If someone can tell me where their wire connects to on the outside fuse block that would be great.
Thanks
Ralph
ViciousV6
400HP/550FTLB
Re: Need Help! Fog Light Wiring
Boostedpimp said:
It helps alittle but i am just not sure what color the wires are that i should looking for. I have an inside and engine harness @ my house and looking for the wires that i need to use off the harnesses.
If you get a chance to look that would be great. I just don't see any purple with white in the old harness that has a conector on it.
Thanks
Ralph
Flyin Ryan
hated cuz he drives fords
Re: Need Help! Fog Light Wiring///Problem Fixed////
just noticed your reply.. I'll peek under the front end tomarrow morning before work for you.. i'll get what colors come out of each fog light for yeah
ViciousV6
400HP/550FTLB
Well Chromy popped over so i could look @ his truck. We have an adtapter on the driver side headlight which gives us the green wire for the highbeams, and then the dk purple wire comes from the fog lights and they both plug into a connector over the power booster(which i forgot once i plugged the washer bottle connector into it once and couldn't figure out why the fuse kept blowing) so being i couldn't figure out where the wire and connector went from the fogs i cut a piece from my ABS wire harness which uses same connector and heat shrank all together and good to go now.
Lights are really bright now.
Ralph
