I can't really say John........ I'm not ducking out on your question, it's just that I did sooooooooooooooooo many upgrades during the last build (including CAS rad, dual Spals, bigger turbo, heads, cam, FAST, injectors, etc...... )
I'm NOT changing it though.......... if nothing else it flows the water a little more evenly and hopefully eliminates any air pockets. My water temps while 60 mph cruzn on a flat and level were like 142*........... surprisingly low (well, they were to me). The EGT's were high (don't 'member xactly what, but up on the gauge) and I was running lean (14's afr) and lotsa timing. At that time, I was running the rear passages open (meaning NOT thru the thermostat). The only drawback was that I don't drive the Sy cold until the fans come on, and with the backs bypassing the stat it took a while to get up to temp. This time I'm trying it thru the stat, just to get up to operating temps a lil quicker.
I have a 140 stat in there, but fans set to come on at 160*.
