My Sy was running good after installing the following: plugs, wires, dist. cap and rotor, new K&N cone filter, K&N breather, oil change, aluminum turbo to IC hose, MSD coil, both PCV valves, adjustable fuel pressure regulator, new walbro 255 fuel pump, battery, 160 deg. thermostat. Truck runs quite well I might add after all this. I drove it for a good 20-30 miles without problem. Then I buy a 10-1 chip and install it. Truck immediately idles badly. It's ok for the first 10-15 seconds and then it kicks down and stubbles almost stalling. I then put the stock chip back in and it still idles like crap. Now I didn't make any chances since the orig. chip is back in which was smooth just 10 minutes before. I grab a new ECM and try again. Same thing, no change. I take it out for a drive and notice a longer turbo lag than normal and do not notice any substancial difference between the various settings on the chip, although the valet and disable mode works and the idle is better (for like 10 seconds) in the T116?? (the mode above stock +, sorry forgot the exact display).
What could be going on here? All is good, change a chip and runs bad. Put in original chip again and still bad :-?
I need some help here, what can I check?
Thanks all!
Thanks all!
