I can't get over 2500 rpms, engine starts spundering and falling on its face. I floor it, and once it gets past 2500 rpms, the tach starts fluxing between 2500 and 2000. And of course it sounds really bad too. I can hear the turbo spooling fine and see it on the boost gauge, it holds fine. I just got a new TC and had the tranny rebuilt, and I can shit between the setting fine, so I don't think its that either. I replaced my plugs, oil, oil filter, and fuel filter recently, so shouldn't be those. My oil pressure is up around 50 to 60, which is normal for acceleration in the typhoon. I thought maybe the Ultimate chip had worked its way out of the board, so I checked it and it was fine. Cruise control works, so I think I have good vacuum. For the little I know about my Typhoon, everything looks ok under the hood, no loose wires or plugs.
So I put it on a computer at my friends shop, everything seemed to be ok except the TPS is only reading 3.72 volts when my foot is to the floor. I know, bad TPS sensor. My problem is that this sensor is less than six months old, can they really go bad that fast. I mean I did get it from the local dealership, so its not any aftermarket junk. The other problem would be how to adjust the new TPS sensor to get the closest to ... I think 4.5 volts?
So has anybody had this type of problem, and what did you do to fix it. Thanks, you guys are always a big help.
